Ana içeriğe geç
Toshiba Portege M300 LCD Replacement
Neye ihtiyacın var
  1. Toshiba Portege M300 LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 LCD Replacement: adım 2, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 2, 2 resimden 2.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 LCD Replacement: adım 3, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 3, 2 resimden 2.
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 LCD Replacement, LCD: adım 4, 2 resimden 1. Toshiba Portege M300 LCD Replacement, LCD: adım 4, 2 resimden 2.
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 LCD Replacement: adım 5, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 5, 2 resimden 2.
    • Remove the rest of the cover by sliding it to the right and lifting the right edge.
  6. Toshiba Portege M300 LCD Replacement: adım 6, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 6, 2 resimden 2.
    • Remove all eight plastic circular covers on the plastic screen bezel.
    • Only seven of these plastic covers will contain screws underneath.
    • Unscrew all seven screws with a Phillips head #000 screwdriver.
  7. Toshiba Portege M300 LCD Replacement: adım 7, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 7, 2 resimden 2.
    • Use a plastic opening tool to separate the screen bezel from the rest of the case.
    • Pull at the top edge of the LCD to separate it from the top part of the case.
    • Only separate the casing and the LCD by an inch—there are still wires connecting them.
  8. Toshiba Portege M300 LCD Replacement: adım 8, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
  9. Toshiba Portege M300 LCD Replacement: adım 9, 1 resimden 1.
    • Flip the LCD over onto the back.
    • Gently pull the connection on the corner of the LCD to disconnect.
  10. Toshiba Portege M300 LCD Replacement: adım 10, 2 resimden 1. Toshiba Portege M300 LCD Replacement: adım 10, 2 resimden 2.
    • Remove the tape connecting LCD to the inverter.
    • Use tweezers to remove the LCD cable from the inverter.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alison Wendt
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G51
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 1,005
