Ana içeriğe geç
Toshiba Portege M300 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Portege M300 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place laptop upside down.
    • Rotate so the battery side is facing away from you.
    • Locate the twelve screws on the bottom of the laptop.
    • Using the correct Phillips head screwdriver remove the twelve screws from the bottom of the laptop.
  2. Toshiba Portege M300 Motherboard Replacement: adım 2, 1 resimden 1.
    • Locate the two screw covers and screws that can be found underneath the screen of the laptop.
    • Once located remove the screw covers and screws from underneath the screen by using the correct sized Phillips head screwdriver.
    • The screen should readily detach from the laptops body.
  3. Toshiba Portege M300 Motherboard Replacement: adım 3, 1 resimden 1.
    • Locate the wires that connect the screen to the laptops body. (They are located at the bottom left side of the screen.)
    • Lift up the black protective cover that the wires lie under.
    • With one hand holding the black cover up, with free hand carefully pull away the wires, removing them from the laptop’s body.
  4. Toshiba Portege M300 Motherboard Replacement: adım 4, 1 resimden 1.
    • Underneath the black protective cover locate the wires that are for the speakers.
    • With one hand holding the black cover up, with free hand carefully pull away the speaker wires, removing them from the laptop’s body.
  5. Toshiba Portege M300 Motherboard Replacement: adım 5, 1 resimden 1.
    • Close laptop.
    • Grip the left and right sides of the top side of the laptop. (Silver portion).
    • Lift gently with both hands upward.
    • Top portion should disengage from the bottom half of the laptop. (Black portion).
  6. Toshiba Portege M300 Motherboard Replacement: adım 6, 3 resimden 1. Toshiba Portege M300 Motherboard Replacement: adım 6, 3 resimden 2. Toshiba Portege M300 Motherboard Replacement: adım 6, 3 resimden 3.
    • With fingers scale the sides of the motherboard and pull back tabs that are holding the motherboard in place to the laptop.
    • Once all tabs are pulled back the motherboard should easily be able to be removed from the bottom half of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Phillips
158 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 801
