Ana içeriğe geç
Toshiba Portege M300 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Portege M300 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 RAM Replacement: adım 2, 2 resimden 1. Toshiba Portege M300 RAM Replacement: adım 2, 2 resimden 2.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 RAM Replacement: adım 3, 2 resimden 1. Toshiba Portege M300 RAM Replacement: adım 3, 2 resimden 2.
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 RAM Replacement, RAM: adım 4, 3 resimden 1. Toshiba Portege M300 RAM Replacement, RAM: adım 4, 3 resimden 2. Toshiba Portege M300 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Turn the computer over onto the back.
    • Use a Phillips head screwdriver to remove the screw holding the RAM cover in place, and lift the cover.
    • One 4.0 mm coarse thread screw.
  5. Toshiba Portege M300 RAM Replacement: adım 5, 3 resimden 1. Toshiba Portege M300 RAM Replacement: adım 5, 3 resimden 2. Toshiba Portege M300 RAM Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to open the silver flaps on either side of the RAM.
    • Once both flaps are released, the RAM should pop up at an angle.
  6. Toshiba Portege M300 RAM Replacement: adım 6, 2 resimden 1. Toshiba Portege M300 RAM Replacement: adım 6, 2 resimden 2.
    • Grasp both sides of the RAM and pull to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alison Wendt
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G51
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 1,244
