Ana içeriğe geç
Toshiba Portege M400 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Portege M400 CD/DVD Drive Replacement, CD/DVD Drive: adım 1, 1 resimden 1.
    • Make sure your computer is securely latched and closed.
    • Locate the CD drive on the right side of your Toshiba Portege M400 laptop and find a small hole right next to the CD drive button.
  2. Toshiba Portege M400 CD/DVD Drive Replacement: adım 2, 2 resimden 1. Toshiba Portege M400 CD/DVD Drive Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, insert them into the small hole next to the CD drive button.
  3. Toshiba Portege M400 CD/DVD Drive Replacement: adım 3, 2 resimden 1. Toshiba Portege M400 CD/DVD Drive Replacement: adım 3, 2 resimden 2.
    • Push the tweezers back into the hole and grab the CD drive door with the other tweezers' appendage.
    • Pull the CD door out carefully to remove the broken or jammed disk.
    • Note: If the CD door still does not open, move on to the next step to see how to remove the CD drive entirely.
  4. Toshiba Portege M400 CD/DVD Drive Replacement: adım 4, 1 resimden 1.
    • Flip the laptop over so its on its face.
  5. Toshiba Portege M400 CD/DVD Drive Replacement: adım 5, 3 resimden 1. Toshiba Portege M400 CD/DVD Drive Replacement: adım 5, 3 resimden 2. Toshiba Portege M400 CD/DVD Drive Replacement: adım 5, 3 resimden 3.
    • Locate screw as seen on picture
    • Using #1 Philips head screwdriver remove the 3.8mm screw.
  6. Toshiba Portege M400 CD/DVD Drive Replacement: adım 6, 2 resimden 1. Toshiba Portege M400 CD/DVD Drive Replacement: adım 6, 2 resimden 2.
    • Locate the lock switch in the center of the laptop.
    • Locate the tab on the end of the end of the CD Drive.
  7. Toshiba Portege M400 CD/DVD Drive Replacement: adım 7, 3 resimden 1. Toshiba Portege M400 CD/DVD Drive Replacement: adım 7, 3 resimden 2. Toshiba Portege M400 CD/DVD Drive Replacement: adım 7, 3 resimden 3.
    • Push down on the lock tab and pull on the CD tab simultaneously.
    • Keep pulling on the CD drive tab until the CD drive comes all the way out.
Sonuç
Spencer Dilley
4 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-17, Maness Fall 2012 Cal Poly, Team 4-17, Maness Fall 2012 üyesi
CPSU-MANESS-F12S4G17
1 Üye
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,175
