Ana içeriğe geç
Toshiba Portege M400 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Portege M400 Screen Replacement, Screen: adım 1, 2 resimden 1. Toshiba Portege M400 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Using a plastic opening tool, remove all stickers covering the screws.
    • Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
  2. Toshiba Portege M400 Screen Replacement: adım 2, 2 resimden 1. Toshiba Portege M400 Screen Replacement: adım 2, 2 resimden 2.
    • Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
  3. Toshiba Portege M400 Screen Replacement: adım 3, 2 resimden 1. Toshiba Portege M400 Screen Replacement: adım 3, 2 resimden 2.
    • With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
    • Slowly pull the plastic panel from the entire laptop.
  4. Toshiba Portege M400 Screen Replacement: adım 4, 2 resimden 1. Toshiba Portege M400 Screen Replacement: adım 4, 2 resimden 2.
    • Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
  5. Toshiba Portege M400 Screen Replacement: adım 5, 2 resimden 1. Toshiba Portege M400 Screen Replacement: adım 5, 2 resimden 2.
    • Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings.
    • Remove all white tape that hold the cords and wirings together.
  6. Toshiba Portege M400 Screen Replacement: adım 6, 2 resimden 1. Toshiba Portege M400 Screen Replacement: adım 6, 2 resimden 2.
    • Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
  7. Toshiba Portege M400 Screen Replacement: adım 7, 1 resimden 1.
    • At this point, the screen should be completely disconnected from the rest of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Varsha Roopreddy
37 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-17, Maness Spring 2013 Cal Poly, Team 4-17, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G17
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Be careful with this procedure, as there are at least 2 different part numbers for the M400, LTD121KM7K has a 32 pin connector, and a different one, LTD121KC6K has a shorter connector for the display which is not compatible. When ordering from Ebay they do not distinguish between them. I would also like a procedure for replacing the complete screen and lid assembly. I can't find it on the net at the moment. Also, be aware that there may be compatibility issues there too.
Elizabeth Donavan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,417
