Ana içeriğe geç
Toshiba Portege R500 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Portege R500 Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Portege R500 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
Sonuç
JRJones
169 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G19
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 416
