Giriş
In this guide we will be dissembling the device so that we can replace the fan in the laptop.
  1. Make sure the device is off to prevent data loss. Slide both latches to the unlocked position to release the battery.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Pull up on the back casing and remove it.
    • Pull up on the back casing and remove it.
  5. Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
    • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  6. Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • The fan should now be free of the laptop and can be removed.
Sonuç
JRJones
121 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G19
3 Üyeler
Bir Yorum
Don't forget the silver compound when re-assembling
Graham Smith - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 15
Her zaman: 2,988
