Ana içeriğe geç
Toshiba Portege R500 Wi-FI Card Replacement
Neye ihtiyacın var
  1. Toshiba Portege R500 Wi-FI Card Replacement, Battery: adım 1, 2 resimden 1. Toshiba Portege R500 Wi-FI Card Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Wi-FI Card Replacement, Wi-FI Card: adım 2, 1 resimden 1.
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Wi-FI Card Replacement: adım 3, 1 resimden 1.
    • Pull up on the back casing and remove it, revealing the Wi-Fi card.
  4. Toshiba Portege R500 Wi-FI Card Replacement: adım 4, 2 resimden 1. Toshiba Portege R500 Wi-FI Card Replacement: adım 4, 2 resimden 2.
    • Unscrew the two 3.5 mm screws from the Wi-Fi card with the Phillips 00 screwdriver.
    • Pull the Wi-Fi card towards the battery slot to release it.
  5. Toshiba Portege R500 Wi-FI Card Replacement: adım 5, 1 resimden 1.
    • Remove the three wires from the Wi-Fi card by pulling them straight up and off.
    • The Wi-Fi card should now be free of the laptop.
    • When removing the wires be sure to remember which wire came from which port, consider marking them so that you can remember.
Sonuç
JRJones
169 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G19
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,278
