Ana içeriğe geç
Toshiba Portege R700-S1312 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Portege R700-S1312 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 3, 3 resimden 1. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 3, 3 resimden 2. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the 40 mm screws from the RAM cover using a Phillips #00 Screwdriver.
  5. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lift and remove the RAM cover to reveal the first of 2 40mm screws holding down the hard drive cover. Remove the screw using a Phillips #00 Screwdriver.
  6. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the second 40mm hard drive cover screw using a Phillips #00 Screwdriver.
  7. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Lift and remove the hard drive cover.
  8. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Connect the drive (in this case a solid state drive) to the laptop using the SATA cable located inside the hard drive placement area.
  9. Toshiba Portege R700-S1312 Hard Drive Replacement: adım 9, 1 resimden 1.
    • Once the drive is connected, carefully insert the drive into the laptop enclosure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,505
