Ana içeriğe geç
Toshiba Portege R700-S1312 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Portege R700-S1312 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 RAM Replacement: adım 2, 1 resimden 1.
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 RAM Replacement: adım 3, 3 resimden 1. Toshiba Portege R700-S1312 RAM Replacement: adım 3, 3 resimden 2. Toshiba Portege R700-S1312 RAM Replacement: adım 3, 3 resimden 3.
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Flip the laptop over.
  5. Toshiba Portege R700-S1312 RAM Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
  6. Toshiba Portege R700-S1312 RAM Replacement: adım 6, 1 resimden 1.
    • Remove the plate covering the RAM.
  7. Toshiba Portege R700-S1312 RAM Replacement: adım 7, 1 resimden 1.
    • Pull the sides holding the RAM in place until there is a slight pop.
  8. Toshiba Portege R700-S1312 RAM Replacement: adım 8, 1 resimden 1.
    • The RAM stick will lift up on its own. Simply remove it.
  9. Toshiba Portege R700-S1312 RAM Replacement: adım 9, 1 resimden 1.
    • Place new RAM into the RAM drive and gently press until there is a slight pop.
Sonuç
To reassemble your device, simply follow steps 1-3 in reverse order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 509
