Giriş
This guide will show you how to replace the back plate on a Toshiba Portege R705-P35 laptop. This is a prerequisite guide to replace internal components like the fan, DVD drive and Wi-Fi card. It is necessary to remove all the back plate screws; be sure to separate the different sizes of screws for easy reinstallation.
Neye ihtiyacın var
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
