Ana içeriğe geç
Toshiba Portege R705-P35 DVD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Portege R705-P35 DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 DVD Drive Replacement: adım 2, 1 resimden 1.
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 DVD Drive Replacement: adım 3, 2 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement: adım 3, 2 resimden 2.
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: adım 4, 3 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: adım 4, 3 resimden 2. Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: adım 4, 3 resimden 3.
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 DVD Drive Replacement, Hard Drive Plate: adım 5, 1 resimden 1.
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 DVD Drive Replacement: adım 6, 2 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement: adım 6, 2 resimden 2.
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 DVD Drive Replacement, Back Plate: adım 7, 1 resimden 1.
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 DVD Drive Replacement: adım 8, 2 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement: adım 8, 2 resimden 2.
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 DVD Drive Replacement: adım 9, 1 resimden 1.
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 DVD Drive Replacement: adım 10, 2 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement: adım 10, 2 resimden 2.
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
  11. Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: adım 11, 2 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: adım 11, 2 resimden 2.
    • Use an opening tool to detach the hard drive connector from the DVD drive.
  12. Toshiba Portege R705-P35 DVD Drive Replacement: adım 12, 3 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement: adım 12, 3 resimden 2. Toshiba Portege R705-P35 DVD Drive Replacement: adım 12, 3 resimden 3.
    • Remove the two 4 mm screws using a Phillips #00 screwdriver.
    • Remove the one 3 mm screw using a Phillips #00 screwdriver.
    • Remove the silver bracket that comes loose.
  13. Toshiba Portege R705-P35 DVD Drive Replacement: adım 13, 3 resimden 1. Toshiba Portege R705-P35 DVD Drive Replacement: adım 13, 3 resimden 2. Toshiba Portege R705-P35 DVD Drive Replacement: adım 13, 3 resimden 3.
    • Pull on the orange bar with your fingers to detach it from the DVD drive.
    • Pull out and remove the DVD drive from the laptop.
Sonuç
Kathryn Hockenbury
833 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Botvin Spring 2022 UMass Dartmouth, Team 1-4, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G4
3 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 179
