Ana içeriğe geç
Toshiba Portege R705-P35 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Portege R705-P35 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 RAM Replacement: adım 2, 1 resimden 1.
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 RAM Replacement: adım 3, 2 resimden 1. Toshiba Portege R705-P35 RAM Replacement: adım 3, 2 resimden 2.
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 RAM Replacement, RAM Plate: adım 4, 3 resimden 1. Toshiba Portege R705-P35 RAM Replacement, RAM Plate: adım 4, 3 resimden 2. Toshiba Portege R705-P35 RAM Replacement, RAM Plate: adım 4, 3 resimden 3.
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 RAM Replacement, RAM: adım 5, 2 resimden 1. Toshiba Portege R705-P35 RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Using a spudger or your fingers, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise.
    • Repeat this procedure with the other metal rod on the opposite side of the RAM stick.
  6. Toshiba Portege R705-P35 RAM Replacement: adım 6, 2 resimden 1. Toshiba Portege R705-P35 RAM Replacement: adım 6, 2 resimden 2.
    • Once the RAM stick pops out to an angle, pull it outward.
Sonuç
Kathryn Hockenbury
833 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Botvin Spring 2022 UMass Dartmouth, Team 1-4, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G4
3 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 143
