Ana içeriğe geç
Toshiba Portege Z835-P330 Solid-State Drive Replacement
Neye ihtiyacın var
  1. Toshiba Portege Z835-P330 Solid-State Drive Replacement, Solid-State Drive: adım 1, 1 resimden 1.
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Solid-State Drive Replacement: adım 2, 1 resimden 1.
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Solid-State Drive Replacement: adım 3, 1 resimden 1.
    • Peel off hard cover to expose interior of device.
  4. Toshiba Portege Z835-P330 Solid-State Drive Replacement: adım 4, 1 resimden 1.
    • Find the solid-state drive located below the battery, and next to the RAM.
    • Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Solid-State Drive Replacement: adım 5, 1 resimden 1.
    • Pull the solid-state drive from its socket
    • The solid-state drive should automatically pop-up from its housing once the screws are removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 1,211
