Ana içeriğe geç
Toshiba Qosmio X305-Q704 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X305-Q704 Screen Replacement, Keyboard: adım 1, 1 resimden 1.
    • Find an edge of the red strip along the edge the computer and pry it off using a spudger.
  2. Toshiba Qosmio X305-Q704 Screen Replacement: adım 2, 2 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 2, 2 resimden 2.
    • Find an edge of the black cover piece around the keyboard and pry it up using the spudger.
  3. Toshiba Qosmio X305-Q704 Screen Replacement: adım 3, 2 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 3, 2 resimden 2.
    • Lift the keyboard up and detach the strip connecting the keyboard to the back of the laptop.
  4. Toshiba Qosmio X305-Q704 Screen Replacement: adım 4, 3 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 4, 3 resimden 2. Toshiba Qosmio X305-Q704 Screen Replacement: adım 4, 3 resimden 3.
    • Remove the keyboard from the Laptop.
  5. Toshiba Qosmio X305-Q704 Screen Replacement, Screen: adım 5, 2 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Unscrew the four 10 mm screws with the Phillips #0 screwdriver.
  6. Toshiba Qosmio X305-Q704 Screen Replacement: adım 6, 2 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 6, 2 resimden 2.
    • Insert the iFixit opening tool into the side of the computer that separates the top and bottom of the laptop. Move the tool along the edge of the laptop until the cover can be separated from the device.
    • Do not remove the panel from the device, as you'll need to disconnect cables before the component can be fully removed.
  7. Toshiba Qosmio X305-Q704 Screen Replacement: adım 7, 2 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 7, 2 resimden 2.
    • Disconnect all wires connecting the top piece to the bottom.
  8. Toshiba Qosmio X305-Q704 Screen Replacement: adım 8, 3 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 8, 3 resimden 2. Toshiba Qosmio X305-Q704 Screen Replacement: adım 8, 3 resimden 3.
    • Disconnect all wires connecting the screen to the inside of the computer.
  9. Toshiba Qosmio X305-Q704 Screen Replacement: adım 9, 3 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 9, 3 resimden 2. Toshiba Qosmio X305-Q704 Screen Replacement: adım 9, 3 resimden 3.
    • Remove the 6 mm screws holding the screen on to the laptop using a Phillips #0 screwdriver.
  10. Toshiba Qosmio X305-Q704 Screen Replacement: adım 10, 2 resimden 1. Toshiba Qosmio X305-Q704 Screen Replacement: adım 10, 2 resimden 2.
    • Remove the screen from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Borden
220 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Botvin Spring 2019 UMass Dartmouth, Team S1-G1, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G1
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 493
