Ana içeriğe geç
Toshiba Qosmio X505-Q860 CD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X505-Q860 CD Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Qosmio X505-Q860 CD Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Qosmio X505-Q860 CD Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 CD Drive Replacement: adım 2, 3 resimden 1. Toshiba Qosmio X505-Q860 CD Drive Replacement: adım 2, 3 resimden 2. Toshiba Qosmio X505-Q860 CD Drive Replacement: adım 2, 3 resimden 3.
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 CD Drive Replacement, Hard Disk Drive Cover Panel: adım 3, 2 resimden 1. Toshiba Qosmio X505-Q860 CD Drive Replacement, Hard Disk Drive Cover Panel: adım 3, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
    • Pull off the part of the case that's now loose by the indicated tab.
  4. Toshiba Qosmio X505-Q860 CD Drive Replacement, CD Drive: adım 4, 3 resimden 1. Toshiba Qosmio X505-Q860 CD Drive Replacement, CD Drive: adım 4, 3 resimden 2. Toshiba Qosmio X505-Q860 CD Drive Replacement, CD Drive: adım 4, 3 resimden 3.
    • Take out the 4.7mm long JIS #0 screw with a JIS Screwdriver.
    • The CD Drive is now loose. Pull it straight out of the side.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 17
Her zaman: 355
