Ana içeriğe geç
Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement, Battery: adım 1, 3 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement, Battery: adım 1, 3 resimden 2. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement: adım 2, 3 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement: adım 2, 3 resimden 2. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement: adım 2, 3 resimden 3.
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement, Hard Disk Drive Cover Panel: adım 3, 2 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Cover Panel Replacement, Hard Disk Drive Cover Panel: adım 3, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
    • Pull off the part of the case that's now loose by the indicated tab.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 304
