Ana içeriğe geç
Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: adım 2, 3 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: adım 2, 3 resimden 2. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: adım 2, 3 resimden 3.
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive Cover Panel: adım 3, 2 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive Cover Panel: adım 3, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
    • Pull off the part of the case that's now loose by the indicated tab.
  4. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive: adım 4, 2 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive: adım 4, 2 resimden 2.
    • Use the JIS screwdriver head to remove the 3.7mm long JIS #0 screws at the base of the hard drive.
  5. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: adım 5, 3 resimden 1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: adım 5, 3 resimden 2. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: adım 5, 3 resimden 3.
    • Next, use the pull tab to pull down and detach the hard drive from the connector.
    • Now the hard drive is loose and can be lifted straight out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 1,409
