Ana içeriğe geç
Toshiba Qosmio X505-Q860 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X505-Q860 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Qosmio X505-Q860 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Qosmio X505-Q860 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 2, 3 resimden 3.
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Toshiba Qosmio X505-Q860 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Locate the plastic bar at the top of the keyboard.
    • Wedge a plastic opening tool under the bar and pop the bar out.
  4. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 4, 2 resimden 2.
    • Unscrew the four 3.6mm long JIS #0 screws using the JIS screwdriver.
  5. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Qosmio X505-Q860 Keyboard Replacement: adım 5, 2 resimden 2.
    • Lift the keyboard to get to the plastic ribbon underneath.
    • Using the Spudger, press a small tab on the left side of the ribbon. Then pull the ribbon out from the casing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 22
Her zaman: 881
