Ana içeriğe geç
Toshiba Qosmio X505-Q860 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X505-Q860 RAM Replacement, Battery: adım 1, 3 resimden 1. Toshiba Qosmio X505-Q860 RAM Replacement, Battery: adım 1, 3 resimden 2. Toshiba Qosmio X505-Q860 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 RAM Replacement: adım 2, 3 resimden 1. Toshiba Qosmio X505-Q860 RAM Replacement: adım 2, 3 resimden 2. Toshiba Qosmio X505-Q860 RAM Replacement: adım 2, 3 resimden 3.
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 RAM Replacement, RAM: adım 3, 3 resimden 1. Toshiba Qosmio X505-Q860 RAM Replacement, RAM: adım 3, 3 resimden 2. Toshiba Qosmio X505-Q860 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the three 4.8mm long screws that secure the RAM cover.
    • Lift the cover off using the indent for leverage.
  4. Toshiba Qosmio X505-Q860 RAM Replacement: adım 4, 2 resimden 1. Toshiba Qosmio X505-Q860 RAM Replacement: adım 4, 2 resimden 2.
    • Use a spudger or your fingers to push the RAM brackets outwards until the RAM pops up.
    • Once the RAM stick is angled up, pull it out along the angle.
    • Repeat this step for the lower ram card.
Sonuç
1Rehber Yorum
How do I bypass the enter password
Richard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 511
