Ana içeriğe geç
Toshiba Qosmio X775-3DV80 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 2, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 2, 2 resimden 2.
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 3, 1 resimden 1.
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 6, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 6, 2 resimden 2.
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Motherboard Replacement, RAM: adım 7, 1 resimden 1.
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 8, 1 resimden 1.
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 9, 3 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 9, 3 resimden 2. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 9, 3 resimden 3.
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Keyboard: adım 10, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Keyboard: adım 10, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 11, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 12, 1 resimden 1.
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 13, 3 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 13, 3 resimden 2. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 13, 3 resimden 3.
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
  14. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Fan: adım 14, 1 resimden 1.
    • Separate the two halves of the base of the laptop.
  15. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 15, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 15, 2 resimden 2.
    • Disconnect the two cables.
  16. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the palmrest assembly.
  17. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 17, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 17, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
  18. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 18, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 18, 2 resimden 2.
    • Unplug the fan-motherboard connector.
    • Remove the fan unit.
  19. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Wifi Chip: adım 19, 1 resimden 1.
    • Detach the two coaxial connections from the wifi chip.
  20. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 20, 2 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 20, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the two screws from the wifi chip.
  21. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove the wifi chip by pulling it out of the PCIe slot.
  22. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Motherboard: adım 22, 3 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Motherboard: adım 22, 3 resimden 2. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Motherboard: adım 22, 3 resimden 3.
    • Disconnect the three ribbon cables.
  23. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 23, 3 resimden 1. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 23, 3 resimden 2. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 23, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the four screws securing the motherboard to the laptop.
  24. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 24, 1 resimden 1.
    • Disconnect the pinned connector.
  25. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove the 4-pin connector housing by gently wiggling it back and forth.
  26. Toshiba Qosmio X775-3DV80 Motherboard Replacement: adım 26, 1 resimden 1.
    • Remove the motherboard.
Sonuç
Jesse Adam Ory
745 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G1
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 950
