Ana içeriğe geç
Toshiba Qosmio X775-3DV80 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: adım 2, 2 resimden 1. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: adım 6, 2 resimden 1. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
Sonuç
Jesse Adam Ory
745 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G1
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 289
