Ana içeriğe geç
Toshiba Qosmio X775-3DV80 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Qosmio X775-3DV80 RAM Replacement, Battery: adım 1, 2 resimden 1. Toshiba Qosmio X775-3DV80 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 2, 2 resimden 1. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 2, 2 resimden 2.
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 3, 1 resimden 1.
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  5. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 5, 1 resimden 1.
    • Using a spudger or plastic opening tool, pry off the service panel.
  6. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 6, 3 resimden 1. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 6, 3 resimden 2. Toshiba Qosmio X775-3DV80 RAM Replacement: adım 6, 3 resimden 3.
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
Sonuç
Jesse Adam Ory
745 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G1
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 386
