Ana içeriğe geç
Toshiba SD-K740 Inverter Board Replacement
Neye ihtiyacın var
  1. Toshiba SD-K740 Inverter Board Replacement, Top Panel: adım 1, 1 resimden 1.
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Inverter Board Replacement: adım 2, 2 resimden 1. Toshiba SD-K740 Inverter Board Replacement: adım 2, 2 resimden 2.
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Inverter Board Replacement: adım 3, 1 resimden 1.
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Inverter Board Replacement, Front Panel: adım 4, 1 resimden 1.
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Inverter Board Replacement: adım 5, 1 resimden 1.
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Inverter Board Replacement: adım 6, 2 resimden 1. Toshiba SD-K740 Inverter Board Replacement: adım 6, 2 resimden 2.
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Inverter Board Replacement, Inverter Board: adım 7, 1 resimden 1.
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Inverter Board Replacement: adım 8, 2 resimden 1. Toshiba SD-K740 Inverter Board Replacement: adım 8, 2 resimden 2.
    • Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
  9. Toshiba SD-K740 Inverter Board Replacement: adım 9, 2 resimden 1. Toshiba SD-K740 Inverter Board Replacement: adım 9, 2 resimden 2.
    • Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
  10. Toshiba SD-K740 Inverter Board Replacement: adım 10, 1 resimden 1.
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force cable, it should slide out with minimal force.
  11. Toshiba SD-K740 Inverter Board Replacement: adım 11, 1 resimden 1.
    • Pull power cord vertically to detach from the casing.
  12. Toshiba SD-K740 Inverter Board Replacement: adım 12, 1 resimden 1.
    • Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
  13. Toshiba SD-K740 Inverter Board Replacement: adım 13, 1 resimden 1.
    • Push the inverter board forward and to the left to remove from the holding ledges.
  14. Toshiba SD-K740 Inverter Board Replacement: adım 14, 2 resimden 1. Toshiba SD-K740 Inverter Board Replacement: adım 14, 2 resimden 2.
    • Lift the inverter board from the back end and pull toward you to complete removal.
Sonuç
Joe Murphy
542 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G16
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,098
