Ana içeriğe geç
Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement
Neye ihtiyacın var
  1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Battery: adım 1, 1 resimden 1.
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 2, 1 resimden 1.
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 3, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 3, 2 resimden 2.
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 4, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 4, 2 resimden 2.
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Lower Case: adım 5, 1 resimden 1.
    • Unscrew all of the visible screws on the bottom of the laptop.
    • The screws circled are not necessary to remove.
    • Keeping track of which hole each screw goes in will speed up reassembly.
  6. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 6, 1 resimden 1.
    • Unscrew the screws located beneath the battery.
  7. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: adım 7, 3 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: adım 7, 3 resimden 2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: adım 7, 3 resimden 3.
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  8. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 8, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 8, 2 resimden 2.
    • Unscrew the two screws near the top of the keyboard.
  9. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 9, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 9, 2 resimden 2.
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  10. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 10, 3 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 10, 3 resimden 2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 10, 3 resimden 3.
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  11. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: adım 11, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: adım 11, 2 resimden 2.
    • Unscrew the screws on either side of the power button circuit board.
  12. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 12, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 12, 2 resimden 2.
    • Pull upward on the small white ribbon cable to detach from circuit board.
  13. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Optical Drive: adım 13, 1 resimden 1.
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  14. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 14, 3 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 14, 3 resimden 2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 14, 3 resimden 3.
    • Using spudger, push the optical drive out to the right.
  15. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: adım 15, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: adım 15, 2 resimden 2.
    • Disconnect both speaker connectors located near the center of the laptop.
  16. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 16, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 16, 2 resimden 2.
    • Unscrew all visible screws on the heat sink shield.
  17. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 17, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 17, 2 resimden 2.
    • Disconnect the monitor connector.
  18. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 18, 3 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 18, 3 resimden 2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 18, 3 resimden 3.
    • Starting from the front right corner pry apart the black bottom from the gray top.
  19. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 19, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 19, 2 resimden 2.
    • Set aside the top half.
  20. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: adım 20, 2 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: adım 20, 2 resimden 2.
    • Unscrew the remaining screws on the heatsink and fan brackets.
  21. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 21, 3 resimden 1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 21, 3 resimden 2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 21, 3 resimden 3.
    • Disconnect the fan power connector.
    • Remove the heatsink and fan.
    • Check the heatsink fins and fan for any dust build-up. If any is found use compressed air to clean.
  22. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: adım 22, 1 resimden 1.
    • Clean the old thermal paste off the CPU and heatsink.
    • Use a q tip to remove the majority of the thermal paste.
    • Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
    • Dry and clean both surfaces with another q-tip.
    • Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kiril Lange
943 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G2
3 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 881
