Ana içeriğe geç
Toshiba Satellite 1415-S105 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite 1415-S105 Hard Drive Replacement, Hard Drive Cover: adım 1, 2 resimden 1. Toshiba Satellite 1415-S105 Hard Drive Replacement, Hard Drive Cover: adım 1, 2 resimden 2.
    • The hard drive is located on the front left of your laptop.
  2. Toshiba Satellite 1415-S105 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Unscrew the single small screw labeled F4 located on the right side of the panel.
  3. Toshiba Satellite 1415-S105 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite 1415-S105 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Insert a spudger into the indent near the screw to pry open and remove the cover.
  4. Toshiba Satellite 1415-S105 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Toshiba Satellite 1415-S105 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Use a spudger to disconnect the hard drive by shifting the entire drive to the right.
  5. Toshiba Satellite 1415-S105 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite 1415-S105 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Lift the hard drive up and out of the laptop.
Sonuç
Kiril Lange
943 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G2
3 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 452
