Ana içeriğe geç
Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement
Neye ihtiyacın var
  1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Battery: adım 1, 1 resimden 1.
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 2, 1 resimden 1.
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 3, 2 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 3, 2 resimden 2.
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 4, 2 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 4, 2 resimden 2.
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: adım 5, 3 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: adım 5, 3 resimden 2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: adım 5, 3 resimden 3.
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 6, 2 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 6, 2 resimden 2.
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 7, 2 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 7, 2 resimden 2.
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 8, 3 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 8, 3 resimden 2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 8, 3 resimden 3.
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: adım 9, 2 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: adım 9, 2 resimden 2.
    • Unscrew the screws on either side of the power button circuit board.
  10. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 10, 2 resimden 1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: adım 10, 2 resimden 2.
    • Pull upward on the small white ribbon cable to detach from circuit board.
Sonuç
Kiril Lange
943 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G2
3 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,624
