Ana içeriğe geç
Toshiba Satellite 1805-S177 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite 1805-S177 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Sonuç
Hannah
227 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S3G5
4 Üyeler
24 adet Kılavuz yazıldı
1Rehber Yorum
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 4,248
