Ana içeriğe geç
Toshiba Satellite 1805-S177 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite 1805-S177 RAM Replacement, RAM: adım 1, 2 resimden 1. Toshiba Satellite 1805-S177 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator.
  2. Toshiba Satellite 1805-S177 RAM Replacement: adım 2, 1 resimden 1.
    • Using a flathead screwdriver or a shiv, insert the flathead of the screwdriver in the space between the plastic piece and the rest of the laptop. Pry the plastic piece off by moving the flathead screwdriver up and down.
  3. Toshiba Satellite 1805-S177 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite 1805-S177 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite 1805-S177 RAM Replacement: adım 3, 3 resimden 3.
    • Using your fingers, push two shorter sides of RAM away from each other.
    • Note: The RAM should pop up automatically.
  4. Toshiba Satellite 1805-S177 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite 1805-S177 RAM Replacement: adım 4, 2 resimden 2.
    • Using your fingers, pull RAM out of the laptop by gentling lifting up.
    • When reinstalling ram be sure to line up the ram correctly with the slot and notch in the ram
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Hannah
227 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S3G5
4 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 2,845
