Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This repaid guide provides a step by step walk-through of how to replace the battery for a Toshiba Satellite 2430-S255
To make sure the battery is not properly working and is in need of replacement, refer to this troubleshooting guide
  1. Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
    • Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Place your left hand on the locking mechanism and slide it all the way to the left. This will move it into the unlocked position. While holding the mechanism in the unlocked position place another finger in the cavity to the right of the locking mechanism.
    • Place your left hand on the locking mechanism and slide it all the way to the left. This will move it into the unlocked position. While holding the mechanism in the unlocked position place another finger in the cavity to the right of the locking mechanism.
  4. Pulling up with your right hand while the locking mechanism in in the unlocked position will release the battery from its socket.
    • Pulling up with your right hand while the locking mechanism in in the unlocked position will release the battery from its socket.
Sonuç
Jacob Zuliani
147 İtibar
1 Kılavuz yazıldı
Takım
UMass Dartmouth, Team S6-G5, Bernier Spring 2018 UMass Dartmouth, Team S6-G5, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 84
