Ana içeriğe geç
Toshiba Satellite A105-S4011 Battery Replacement
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite A105-S4011 Battery Replacement: adım 2, 2 resimden 2.
    • Hold the release switch and pull out the battery towards you.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Lucas Salisbury
73 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G14
4 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - Yanıt
The part number is PSUB2U-00K00P
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,260
