Ana içeriğe geç
Toshiba Satellite A105-S4011 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4011 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite A105-S4011 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite A105-S4011 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Make sure to turn off the laptop, unplug the device and/or remove any batteries.
    • Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on.
    • Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
    • Once that section has popped up, work on pulling the rest of the plastic piece up and out, alternating from left to right.
  2. Toshiba Satellite A105-S4011 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite A105-S4011 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite A105-S4011 Keyboard Replacement: adım 2, 3 resimden 3.
    • Completely remove the plastic piece from the body of the laptop.
    • Using the Phillips 1 screwdriver, unscrew the two 3mm screws located at the top corners of the keyboard. (See the second picture for additional clarification.)
  3. Toshiba Satellite A105-S4011 Keyboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite A105-S4011 Keyboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite A105-S4011 Keyboard Replacement: adım 3, 3 resimden 3.
    • Without yanking, lift the keyboard up carefully.
    • Now that the board is free, cautiously undo and pull free the ribbon that connects the keyboard to the body of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lucas Salisbury
73 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G14
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,607
