Ana içeriğe geç
Toshiba Satellite A105-S4011 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4011 RAM Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4011 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite A105-S4011 RAM Replacement: adım 2, 2 resimden 2.
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
    • This screw cannot be taken out, it is a "captive" screw.
  4. Toshiba Satellite A105-S4011 RAM Replacement: adım 4, 1 resimden 1.
    • Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
    • Be careful when prying the back cover off because you may damage the cover or crack the plastic.
  5. Toshiba Satellite A105-S4011 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite A105-S4011 RAM Replacement: adım 5, 2 resimden 2.
    • Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
    • Grounding yourself may be a good idea before actually touching the RAM module. This entails touching a conductive metal in order to remove any excess static energy in your body.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas Salisbury
73 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G14
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,324
