Ana içeriğe geç
Toshiba Satellite A105-S4074 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite A105-S4074 Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite A105-S4074 Battery Replacement: adım 2, 3 resimden 3.
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
Sonuç
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Ryan Bortnick
722 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S2G1
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 422
