Ana içeriğe geç
Toshiba Satellite A105-S4284 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 1. Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 2. Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Turn the laptop around 180 degrees.
    • Unscrew the 4 mm screw with the Philips #1 screwdriver.
    • Lift and remove the hard drive cover.
  3. Toshiba Satellite A105-S4284  Hard Drive Replacement: adım 3, 3 resimden 1. Toshiba Satellite A105-S4284  Hard Drive Replacement: adım 3, 3 resimden 2. Toshiba Satellite A105-S4284  Hard Drive Replacement: adım 3, 3 resimden 3.
    • Pull on the rubber tab to slide the hard drive to the left.
    • Pick up the near side of the hard drive and pull it out the back.
Sonuç
Bir başkası bu kılavuzu tamamladı.
pfedigan
11 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G23
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 19
Her zaman: 2,526
