Ana içeriğe geç
Toshiba Satellite A105-S4284 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  3. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 3, 3 resimden 3.
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  4. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 4, 2 resimden 2.
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  5. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 5, 3 resimden 1. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 5, 3 resimden 2. Toshiba Satellite A105-S4284 Keyboard Replacement: adım 5, 3 resimden 3.
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
pfedigan
11 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G23
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 16
Her zaman: 1,511
