Ana içeriğe geç
Toshiba Satellite A105-S4284 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 RAM Replacement, RAM: adım 2, 2 resimden 1. Toshiba Satellite A105-S4284 RAM Replacement, RAM: adım 2, 2 resimden 2.
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite A105-S4284 RAM Replacement: adım 3, 2 resimden 2.
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 RAM Replacement: adım 4, 3 resimden 1. Toshiba Satellite A105-S4284 RAM Replacement: adım 4, 3 resimden 2. Toshiba Satellite A105-S4284 RAM Replacement: adım 4, 3 resimden 3.
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
Sonuç
Bir başkası bu kılavuzu tamamladı.
pfedigan
11 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G23
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 2,164
