Ana içeriğe geç
Toshiba Satellite A205-S4577 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A205-S4577 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Using a Phillips #00 screwdriver, remove both 4mm screws.
  2. Toshiba Satellite A205-S4577 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Lift the cover to reveal the old hard drive.
    • Carefully detach the hard drive from the SATA/Power connector.
  3. Toshiba Satellite A205-S4577 Hard Drive Replacement: adım 3, 1 resimden 1.
    • After removing the old hard drive, place the new hard drive into the bay, and firmly reattach it to the SATA/Power connector.
Sonuç
Daniel Johnson
108 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G6
5 Üyeler
33 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 2,392
