Ana içeriğe geç
Toshiba Satellite A205-S4577 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A205-S4577 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Keyboard Replacement: adım 2, 1 resimden 1.
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Keyboard Replacement, Speaker Cover: adım 3, 3 resimden 1. Toshiba Satellite A205-S4577 Keyboard Replacement, Speaker Cover: adım 3, 3 resimden 2. Toshiba Satellite A205-S4577 Keyboard Replacement, Speaker Cover: adım 3, 3 resimden 3.
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Keyboard Replacement: adım 4, 1 resimden 1.
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 Keyboard Replacement, Keyboard: adım 6, 1 resimden 1.
    • Remove the two 4mm flat-head screws indicated in the photo.
  7. Toshiba Satellite A205-S4577 Keyboard Replacement: adım 7, 1 resimden 1.
    • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
    • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
  8. Toshiba Satellite A205-S4577 Keyboard Replacement: adım 8, 1 resimden 1.
    • The Ribbon Cable must be disconnected here to release the keyboard.
    • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
    • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
    • You can now lift and remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Johnson
111 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G6
5 Üyeler
33 adet Kılavuz yazıldı
3 Yorum
When I got to step 8 in removing the keyboard, the green ribbon cable is connected to a white pin connector. The while pin connector came off. How can I reconnect it?
Thanks
Dave
dave@mediabistro.com
dave argie - Yanıt
Is it the actual cable connection or the push tab that holds the flex cable in place?
South30 -
Hi Judson
It is the actual connection that appears as white in the picture. It came off.
Thx
Dave
dave arganbright - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 2,079
