Ana içeriğe geç
Toshiba Satellite A205-S4577 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A205-S4577 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Identify the rectangular plastic RAM cover located in the bottom part of your laptop.
    • Remove the 4mm flat-head screws on the RAM cover.
    • Use a plastic opening tool to pry the RAM cover upward.
  2. Toshiba Satellite A205-S4577 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the RAM cover.
  3. Toshiba Satellite A205-S4577 RAM Replacement: adım 3, 1 resimden 1.
    • Press the two tabs on the side of the PC2-5300 2 GB RAM Chip to unlatch it.
    • To remove the PC2-5300 2 GB RAM Chip, pull it out at a slightly upward angle.
  4. Toshiba Satellite A205-S4577 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite A205-S4577 RAM Replacement: adım 4, 2 resimden 2.
    • To replace the ram, insert the new PC2-5300 1 GB RAM Chip you have gathered back into the laptop.
    • Make sure the notch in the middle of the stick is lined up correctly and push firmly into place.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the laptop. Repeat process for additional RAM sticks.
  5. Toshiba Satellite A205-S4577 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite A205-S4577 RAM Replacement: adım 5, 2 resimden 2.
    • To replace the ram, insert the new RAM sticks you have back into the computer.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the computer. Repeat process for additional RAM sticks.
  6. Toshiba Satellite A205-S4577 RAM Replacement: adım 6, 1 resimden 1.
    • Screw the back plate of the RAM back onto the device.
Bitiş Çizgisi
Daniel Johnson
111 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G6
5 Üyeler
33 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 1,486
