Ana içeriğe geç
Toshiba Satellite A205-S4577 Speaker Cover Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Speaker Cover Replacement: adım 2, 1 resimden 1.
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: adım 3, 3 resimden 1. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: adım 3, 3 resimden 2. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: adım 3, 3 resimden 3.
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Speaker Cover Replacement: adım 4, 1 resimden 1.
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Speaker Cover Replacement: adım 5, 1 resimden 1.
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
Sonuç
Daniel Johnson
108 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G6
5 Üyeler
33 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,297
