Ana içeriğe geç
Toshiba Satellite A205-S5812 RAM Module Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A205-S5812 RAM Module Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 RAM Module Replacement: adım 2, 1 resimden 1.
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 RAM Module Replacement: adım 3, 1 resimden 1.
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 RAM Module Replacement, RAM Module: adım 4, 1 resimden 1.
    • Remove the two 3mm Phillips #00 screws holding the plastic cover over the RAM modules.
  5. Toshiba Satellite A205-S5812 RAM Module Replacement: adım 5, 1 resimden 1.
    • Gently lift the plastic cover. Once the plastic cover is removed, the two RAM cards will be visible.
  6. Toshiba Satellite A205-S5812 RAM Module Replacement: adım 6, 2 resimden 1. Toshiba Satellite A205-S5812 RAM Module Replacement: adım 6, 2 resimden 2.
    • Press the silver tabs away from the RAM stick to remove it. Both RAM modules can be removed using this technique.
    • Do not touch the gold strip on the RAM card because the oils on your fingers can potentially cause damage to the module.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 290
