Ana içeriğe geç
Toshiba Satellite A210 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A210 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite A210 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: adım 4, 3 resimden 1. Toshiba Satellite A210 Keyboard Replacement: adım 4, 3 resimden 2. Toshiba Satellite A210 Keyboard Replacement: adım 4, 3 resimden 3.
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite A210 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: adım 6, 1 resimden 1.
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Youlen
49 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G5
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
very useful. THANKS
ANDREAS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 2,805
