Giriş
In this guide you will learn how to remove the RAM. In the case of a broken or unresponsive RAM a replacement may be required. Before begining this guide you should have all required tools that are listed.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
In order to reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
