Ana içeriğe geç
Toshiba Satellite A215 S4697 Optical Drive Replacement
Neye ihtiyacın var
    1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: adım 1, 3 resimden 3.
      • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
      • Find the battery compartment.
      • Slide the left slider which is just beneath the battery compartment into its leftmost position.
      FixBot'a Sor
      Yorum Ekle
    2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 2, 3 resimden 3.
      • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
      • Do not touch the gold nodes inside the compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
      • Turn computer over so that the battery compartment is facing up and is at the top.
      • Locate and unscrew one captive Phillips #1 screw located at the center.
      • A captive screw cannot be completely removed from the device's component.
      FixBot'a Sor
      Yorum Ekle
    2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 4, 3 resimden 3.
      • Use a plastic opening tool to open the motherboard access cover.
      • Do not touch the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 5, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 5, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 5, 3 resimden 3.
      • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
      FixBot'a Sor
      Yorum Ekle
    4. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 6, 2 resimden 2.
      • Flip your device right side up, and rotate it so that the optical drive is facing you.
      • Insert a paper clip into a manual release switch located to the right of the automatic release button.
      • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
      FixBot'a Sor
      Yorum Ekle
    5. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 7, 2 resimden 2.
      • Gently pull out the disk drive until you can see the metallic case of the optical drive.
      • Hold the metal case and continue to pull the drive out toward you.
      FixBot'a Sor
      Yorum Ekle
    6. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 8, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 8, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 8, 3 resimden 3.
      • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
      FixBot'a Sor
      Yorum Ekle
    7. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 9, 3 resimden 1. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 9, 3 resimden 2. Toshiba Satellite A215 S4697 Optical Drive Replacement: adım 9, 3 resimden 3.
      • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Mike Dongyub Ryu
566 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 üyesi
CPSU-MANESS-S13S4G12
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 29
Son 30 gün: 94
Her zaman: 5,113
