Giriş
This guide will teach you how to get your laptop apart and replace it with a new screen. To put your laptop back together just follow the steps in reverse. Remember to make sure to keep track of your screws!
Neye ihtiyacın var
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Place laptop right side up on a flat and clean surface. Open the laptop.
Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
Bu adımda kullanılan alet:Tweezers$4.99
Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
Pull out the cable and completely remove the keyboard.
Close the lid and flip the laptop over so that the bottom side is facing you.
Remove nineteen 8mm Phillips #1 screws, labeled with "F8."
Locate and Remove two "f4" screws as well.
Begin by carefully removing the rubber bumper pads located at each corner of the plastic screen casing.
Using a Phillips screwdriver you may unscrew and remove the screws located directly under the the rubber bumper pads. Remember to keep track of the removed screws!
Gently place screen face down on laptops hardware
Detach tape that is over the screens connection to the laptop, and detach connection with tweezers by pulling back
Disconnect blue wire near the base of the screen with tweezers, by pulling it straight out
2 farklı kişi bu kılavuzu tamamladı.
