Ana içeriğe geç
Toshiba Satellite A215-S4757 Display Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: adım 1, 2 resimden 1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: adım 1, 2 resimden 2.
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 2, 3 resimden 1. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 2, 3 resimden 2. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 2, 3 resimden 3.
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 3, 3 resimden 1. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 3, 3 resimden 2. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 3, 3 resimden 3.
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 4, 2 resimden 1. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 4, 2 resimden 2.
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 5, 3 resimden 1. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 5, 3 resimden 2. Toshiba Satellite A215-S4757 Display Screen Replacement: adım 5, 3 resimden 3.
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Brown
409 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S12G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 340
