Ana içeriğe geç
Toshiba Satellite A215-S4757 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A215-S4757 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Locate the RAM storage space on the back of your Toshiba Satellite.
  2. Toshiba Satellite A215-S4757 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite A215-S4757 RAM Replacement: adım 2, 2 resimden 2.
    • Unscrew the two screws holding the plate to the laptop.
    • Gently lift the lid, and remove it form the Satellite.
  3. Toshiba Satellite A215-S4757 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite A215-S4757 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite A215-S4757 RAM Replacement: adım 3, 3 resimden 3.
    • Identify the clips on each side of both RAM components that are holding them in place.
    • To remove each component, simply push each clip gently outward until the component pops upward.
  4. Toshiba Satellite A215-S4757 RAM Replacement: adım 4, 1 resimden 1.
    • Gently pull and remove the RAM component, and repeat for the second component laying underneath the first.
  5. Toshiba Satellite A215-S4757 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite A215-S4757 RAM Replacement: adım 5, 2 resimden 2.
    • Be sure to match each RAM components female insert, with the laptops male insert during reassembly. If you do not reinstall the components correctly your motherboard may fry.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Brown
409 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S12G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 353
