Ana içeriğe geç
Toshiba Satellite A215-S7425 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 5, 3 resimden 1. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 5, 3 resimden 2. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Slide case away from hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Marianne
647 İtibar
6 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-2, Prince Fall 2014 Pasco Hernando, Team 5-2, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S5G2
10 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 1,019
