Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Turn the device so the top side is facing up. Open device to expose key board.
Locate plastic bezel above keyboard and use flat side of spudger to pry away from device.
Remove 2 Phillips 3.1 mm size screws from each side above the keyboard.
Gently lift keyboard a few inches above device, exposing the attached ribbon cable.
Gently disconnect the ribbon cable from the motherboard, it should easily slide out from the connector.
2 farklı kişi bu kılavuzu tamamladı.
